failing on emissions?
hi
recently had my 1.0 facelift moted nd it failed on emmissions. any sugestions? ive looked at the air filter nd it looks clean.
thanks
no mods, nd a never got a print out, it was a bit dodgy, cause it passed. i jus got told tht it shud of failed on emissions. mite of jus bin cause it was cold? ano wen i first start it it idles at bout 1500rpm, till it warms up a bit? cud tht b anything to do with it?
You should by law get a copy of the emissions test results with the mot certificate.. pass or fail..!
It would help if you took the car for a good rag before hand to get the Cats Hot enough to work properly.
if it idles 1500rpm cold then slows to 700rpm warmed up, then its normal
Same for me (Y)
