misfire on cyl 3
It could be multiple things from old/damaged/fouled spark plugs, a coil going bad or split on the boot, bad wiring, bad fuel, or bad injector....
if it's cleared just keep an eye on it. If it was me and it came back I would first check the plugs and if they are good swap coils with another cylinder to see if the problem moves to another cylinder (some of this assumes it's a petrol engine!)
