Theres a little plastic box on the right of it (with writing on it) i cant get it out but looks like it may be a fuse box or similar?) Thats in the way of me getting the cap off.
Im looking for my cam to take pics of it but seem to have misplaced the bloody thing (typical)
you could unhook that fusebox MQ, but you should,nt need to really, you could pull the 4 HT leads off the cap first if its too tight (you,re best to mark their order/position clearly first tho )
Ps. I was careful to make sure I put the right wire in the right place. But just out of curiosity, what owuld happen if the wires were in the wrong place? I'm not going to do it, but just trying to learn a bit as I go along :suspect:
ive measured the 3 hex bolts as 5.5mm........... i dont have a 5.5mm socket i cant get mole grips on the bolts. have also tried imperial spanners but nothing seems to work..... do i just need to buy a 5.5mm spanner?
cheers pollyp. i tried that but because the fuse box is in the way i can only get a small screwdriver in there. The bolts seem very tight. I don't want to round them by doing it badly. if i use a small screwdriver, i cant get the necessary force to break the stiff thread.
