Cheers for the reply ed, maybe you should try that one day if ur stripping your st an have another ma sitting around at the same time. Although its probably to agressive to run properly (18 degrees can be a difference between standard and road/rally cam). You dont happpen to know the duration of my re-profiled cam do you? *brain cogs ticking* I think il have to give them a ring.
