micra_pete
Datrats
please knock 10% off shown prices
NEW!!!! MICRA 190mm HD clutches - $319 - £135
We have had these clutches custom made for HD micra applications. The clutch uses an organic plate, higher clamp load diaphragm and 190mm pressure plate.
These clutch kits will bolt up to standard flywheels. If used on after market flywheels, check the contact surface diameter is large enough for this plate.
NOTE! This kit will soon be available with a 3 button ceramic cushion plate.
MICRA ADJUSTABLE CAM GEARS - $360 - £152
Used to set up camshafts to specification or modify timing of existing cams.
WARNING! VARYING CAM TIMING MUST BE CARRIED OUT BY A SUITABLY QUALIFIED PERSON OR EXTENSIVE ENGINE DAMAGE WILL RESULT
Custom alloy K11 micra radiators - $675 - £287
These have twice the thermal rejection capacity of the stock radiator.
CUSTOM CON RODS FOR HIGH KILOWATT MICRA'S! Set of 4 rods $1500 - £637
The rods are to suit CG13 or CG10 using stock 18mm gudgeon pins. If used with forged pistons for NA engine the rods are stock length. For forced induction engines the rods are made 2mm shorter to allow an larger bowl to be machined in the piston to lower compression.
FORGED PISTONS $1350 With ceramic coating on crown and friction modified skirts. Add $250 - £573
Set of 4 forged pistons 1.2,1.2 2.8 mm rings and 18mm gudgeon pins.
ALLOY FLYWHEELS - $780 - £332
Micra flywheels NOW WITH 190 mm FRICTION FACING!!!
These new design flywheels will accept either 180 mm standard sized clutch assemblies or 190mm extra heavy duty clutch assemblies.
The flywheels have lower mass than steel wheels (3.3 kg). The ring gear is also replaceable. These wheels have a higher thermal absorption mass than steel flywheels due to the greater volume of alloy. The friction face insert is an armoured steel plate that is also replaceable if damaged due to extreme use.
[attachmentid=98]
SUPER CHARGER 1.5:1 STEP UP PULLEY (10 PSI) SUITS TOYOTA SC12 $550 - £233
MADE FROM SPECIAL GRADE OF BILLET ALUMINIUM USED FOR AIR FRAMES OF COMBAT AIRCRAFT
CG13 race cams. - $1320 - £560 with donor cams.
Cams are individually spray welded to build up each lobe. The lobes are then ground to the required profile.
[attachmentid=97]
[attachmentid=98]
[attachmentid=97]
