Hi, i have been using this forum for awhile now but have not needed to post. I have found it very helpful in fixing my red rocket.
Anyways my prob is to do with the gear selection and clutch, when i first got the car afterwhile it got very difficult to put it into first gear while stationary. to the put of having to start the car in gear with the clutch down. I tried adjusting the clutch but there was little improvement.
However i got a new clutch fitted and all was well until about a year later the problem has resurfaced. I have had to modifiy the clutch cable as clutch cables do not fit properly. The outer sheath is too long, or the distance from the clutch arm to the outer cable mounting point is too small. This solved the problem for a little bit. But now has come back again.
I can't believe its the clutch, have only done approx 4000 miles on it. so has anyone got any ideas on what it could be? would be very grateful.
Many thanks
Tom
Many thanks
Tom
