JDMicra Jun 22, 2012 #1 Hi all how do I adjust the clutch cable on my K11 Super S? As it is the clutch pedal works fine, but I'd like it to bite a little bit higher. Thanks!
Jay101 Black&Yellow Jun 22, 2012 #2 If you look to the left handside of the battery. Buried a little deep you will see the clutch fork.(on top of the gearbox.) 10mm locking nut. Slacken that off and there is a disc that you turn to adjust. Check bite point and tighten locking nut
