chikity check. before you wreck, thread
r-reg-sr
Site Supporter
making sure i haven't got this badly wrong.check me out if i done didly screwed it up.
ratatatat@ Se@n front stabiliser bar bushes ebray special you fitted too?
also flung in a ball joint
as I say it's a chikety check before I get wrecked :) his neck.
OP
OP
r-reg-sr
r-reg-sr
Site Supporter
sweet man drives ok but getting a tap noise on suspension lift up. darn ball joint is 3 or 2mm odd to long and seems to need another circlip (is that it's name) to hold it fully within its housing.not bad for a 2.99 job.thanks frank boy
OP
OP
r-reg-sr
r-reg-sr
Site Supporter
no you wouldn't cause i was doing this on the solo :)
more rust under no ?
plus don't forget this is the r-reg I am the r-reg slice a piece off they maa's buttocks then throw it for the foxes in a hedge cause theyz absolutely no hedgehogs left..I think.
OP
OP
r-reg-sr
r-reg-sr
Site Supporter
Yeh azzyman don't watch nothing plus cover yo ears homey I got the extra circlip in now bowl joint is firm in its housing. Thanks
OP
OP
r-reg-sr
r-reg-sr
Site Supporter
wrecked in affect.
stabiliser bar bush replaced better? give us your taunts like thoughts.
OP
OP
r-reg-sr
r-reg-sr
Site Supporter
What bush is that looks like a socket and banged with a hammer lol
oh Yeh, the thread on the bar is so short you have to make up the gap with the sleeve provided.
all the seller has to do is cut the thread longer.or we should source it.
where can the original bar and stuff be got for a good price cause these is scrap cars in it.
Yeh true so the new bushes makes up the right space and gap,
