cg10 to cg13 swap
hi, this is my fisrt thread and i want to covert it from a 1.0 to a 1.3 its an s reg late 1998 (pre coil pack). i want to know if i need to swap everything, g/box, shafts, loom, ecu ect or will the 1.3 engine match up with the 1.0 box and will my original loom match the 1.3's injectors, lambda sensor, alternator ect, basically im looking to find out which is the simplest route to go down and any problems im likely to occur along the way as this is my first engine conversion, any useful imformation welcome, thanx
