ball joints & hub bearings
smidge
Small Car Enthusiast
Site Supporter
looking to replace BOTH of the above....
are they the same as the old style K10 or do K11 parts fit up same as brakes, shocks etc?
Ball joint are part of the wishbone so the whole unit has to be replaced and a hole drilled for the anti-roll bar .not sure about the bearings
Ed said at some point that thr front end is different from a normal K10, does that mean the wishbones are different also?
It is different yes but to replace the ball thats what has to be done,use k10 wishbones and drill the hole for the antiroll bar link.to look at the wishbones are identical minus the hole
ah okay cool, thanks Baz... i'll see if i can get my hands on some somehow!
just a note figaro wishbones should already have the hole for the ARB ;) so you may be able to use those as they are easier to come by
