plum Mar 17, 2013 #1 I can get my hands on a set of ats classic wheels, 8"rear 7"front, will they fit my k11, if not how much work is it to make them fit? Thanks
SK193 Mar 18, 2013 #2 Do you know the pcd & centre bore of them? as long as the pcd is right they'll fit, you can always get spigot rings if the cb isn't quite right
markbognor Ex. Club Member Club Member Mar 18, 2013 #3 CB will be vw friendly - so they will need machining out to 59.1. Fronts will go on fine, rears are likely to require some arch work, though the offset of the 8"s is fairly high. Check out mintyfresh black supers. That has 7"s all round.
OP OP plum Mar 18, 2013 #5 Yeh they are of a vw polo, mjtm u say u had to widen the cb is that hard, I know nothing. thanks
