ats classic
I can get my hands on a set of ats classic wheels, 8"rear 7"front, will they fit my k11, if not how much work is it to make them fit?
Do you know the pcd & centre bore of them? as long as the pcd is right they'll fit, you can always get spigot rings if the cb isn't quite right
CB will be vw friendly - so they will need machining out to 59.1. Fronts will go on fine, rears are likely to require some arch work, though the offset of the 8"s is fairly high. Check out mintyfresh black supers. That has 7"s all round.
