CMF_dandaman2234
» CMF MemberHi I just install my amp into my K11. It worked for about 10 secs then nothing. I looked at the amp 'on' indication light and noticed it stayed on when the stereo was off. I routed around for the problem and realised that I had wired the Remote cable to the Power terminal, and the Power cable to the Remote terminal. I switched them around and now the amp doesn't turn on at all. I looked at the fuse near the battery and in the amp, they seemed to be A.OK. Could I have blown the remote cable as I was accidental using it as a power cable?
Or is the amp DEAD??
PS. I used another an additional cable running from GROUND on the amp to the back of my HeadUnit to solve any ground loop/hissing problems if that helps.
Any suggestions?
Dan
Any suggestions?
Dan
