1.4t advice
OP
OP
L
Is there things I should be checking? It’s on standard injectors atm also.. there’s no second lambda fitted as no bung in the exhaust stupid exhaust fab didn’t put one in! Would that matter as its post cat?!
frank
i doubt if it would be those leon, the 2nd head gasket will be 5hp down off boost but not really noticable
cam timing maybe ?
OP
OP
L
Okay that grate! If not then tdc the crank, pop the side cover off loser the tensioner adjust cams re do everything back up 😏
OP
OP
L
Also frank I have removed the carbon canister just by yanking it out 🤷‍♂️ Will that make a difference should I chuck it back in?
