Wiring K11
My Nissan micra K11 had a aftermarket stereo system and blue led's in the clocks which worked fine together. I was going to swap it for a 53 plate Corsa so i took all of my stuff out. Then I decided to keep the car so i sorted it out again and now the stereo wont work and neither will the dash lights, also when i rev the car up then the interior lights and brake lights will come on because something is faulty. Please can someone help me if they can because i really don't know what has happened thank you.
When my brother fitted the cd player in my k11 all the electrics went hinky <_<
Wouldn't start and even my horn failed
Double check all wiring is correct, you're earthed and not shorting out.
Then check all the fuses.
...That's the extent of my helpful knowledge, but I hope that does the trick ;)
