Windscreen trim
Hi folks, hoping someone might be able to help with a quick question. Recently took hold of my mums old Micra as a run about and its in sterling condition car the windscreen which was replaced at some point and appears the guy who did it might have prized it out with a crow bar and sealed it badly.
I've noted a couple of rust spots I want to get in and tackle. However Haynes etc say its all beyond the scope of the home mechanic blah blah. Simply put if I rag on the old seal and remove it... is it a one shot affair i.e. it can't go back ?
yeah the trims are one time use.you could pull the trim out,do your repairs & talk nicely to a trade fitter to fit a new trim for you.Or if you're good with the sealer you might be able to create your own trim
