L.Williams
soundcloud.com/lwilliamsmusic
also, can someone answer this? if i buy a pipecross panel filter.. will it be better performance / fuel economy /sound (lol) than a cone filter ??
okay cool thats dont sound too bad, thanks broJay recently had a dyno at 93HP, he has an Almera airbox and a 4-2-1 manifold. So I think it's safe to say it helps a bit but it's probably dependant on exhaust mods too.
Sound? With a CAI mine is much quieter than a K&N, still a bit of noise but very muffled. Nice.
i agree, the old bum dyno is,nt very accurate and if you are already running lean the GA airbox will probably make it even worse.It may gain you a little power but imo not enough to make it noticeable but thats only my opinion
haha okay cool manYes I think you feel a difference .. on the theory side..you let more air in and exhaust gases outer quicker ..more power you'll have lol noise wise when mine hits around 5k I get a whistle sound.. probably cold air feed
ohhhh interesting... hmmi agree, the old bum dyno is,nt very accurate and if you are already running lean the GA airbox will probably make it even worse.
my SR20 t/b made the car actually slower, till i fitted bigger injectors
ahhh okay cool ,sounds okay i spose what if i add a pipecross panel filter too it ?I didn't really notice a difference tbh, sounds very throaty of you aren't running a sealed cold air feed!
yeah 1.0... and i know :/ just wanna feel a little more boost if you like when i put my foot down...more pull, acceleration etcIf your fitting it on a 1.0,
standard power around 50??
You wont find a 10% increase in power from the filter you might find a gain of 1/2 bhp 3 if your really lucky but you wont be able to feel this at all....
However every little helps
I don't know of much that helps at low revs.
I find my 1.0 with full decat, Almera airbox, 4-2-1 is pretty nippy in the higher revs (3.5k+) but lacks punch at lower revs (2k-2.5k)
ahh okay, so mostly it helps out above say 4k ? thats when you feel it ... okay cool!!I don't know of much that helps at low revs.
ahhh yeah ? niceee i got a powerflow exhaust coming from suluR soon off here, almera air box, hopefully getting some twin spark HT leads, and a £3 turbo whistler for the exhaust off ebay lmao naa scrap the last bit lmaoi had mine with an omp panel filter, ran a cold air feed near the hole but didnt seal it. decat the front, peter lloyd exhaust, bosch super 4s and was a very noticeable difference, and sounded amazing. hmmmm i miss it soooo bad
thanks for the help mate! i may need you to send me a link or two on what i need ?you need to buy HT lead from this website. i made a set that registered at 0 Ohms on the mutimeter. the standard ones range between 2.5K Ohm and 4.2K Ohm..... after that, there should be some slightly gapped bosch super 4s/
