Wheel Fitting Help
Picking up a set of Almera GTI alloys tomorow for my K11, just checking that I can use my standard wheel bolts (and a locking nut set) or will I need extended bolts. Not used to all this Jap stuff as I used to have a clio 1.8 16v so am in French mode!
Thanks in advance :blues:
Mike
I have a set of 15 inch genuine nissan alloys which I believe are off the almera on my k11 they fitted with standard nuts correctly and with no clearance problems-jon
no you cant use standard wheel bolts if you have steels on....you need alloy wheel nuts....and then put your locking ones on.
Arse, I do have steelies on there at the moment so i'd need new wheel bolts then :down:
They have 55's profiles on them at the moment, surely it wont scrub at standard height its like a 4x4! :laugh:
Miogh end up selling them then if it's going to be too much messing about only wanted a cheap set of wheels
