Nissan Micra K12 - front end parts (k-frame, lower control arm, engine mounts and positions, steering rack, front right-hand quarter cut). Wanting to know if the design has changed at all (or much) with earlier models compared to 2010.
I'm not sure if you managed to get your answer....or if this will help.
I know this is a really old thread too...but hopefully may help someone at least
My mum and I both have UK specification K12's, hers is a 2003 (early model) SVE and mine is a first UK facelift 2005 Sport...our suspension wishbone arms are identical as are various mounts and other such components but the track rod ends are different for some unknown reason
...I believe mine (2005) are still the same as later models (all the way upto 2010)
of course other differences between models will mostly be engine related
Mums is a 1.4 petrol and mine is diesel...so our oil and air filters are different, my sump (and engine) is from a Renault...hers is not
They changed grills here in the uk...but the only issue changing between may be that indicator bulbs need to be orange instead of clear (or vice versa)...or are Aus K12 indicator (turning signals) in the main headlamp like on the Thai models?
....another change here in the UK was between my age of K12 (2005) and a later (2nd Facelift) model, 2008 on... was the Wing/door mirrors changed slightly in size and shape...along with a few variations to the interior trim (the cup holder changed from a flip down to just a shaped piece.)
bumpers changed a few times but as far as I've been able to tell (comparing mine and mums) is the mounting points to the body/frame are the same throughout
EDIT:
just a note the interior A pillars and C pillar trims don't appear to have changed and will fit between 3 and 5 door models also (I personally changed my C pillar trim from my scratched 3 door to that from a newer 2007/8 5 door
...same goes for the hatch/boot lid interior trim....parcel shelf...seats (although front seats not between 3/5 doors due to sliding seat needed in 3 door)
