Angus Robinson Apr 28, 2014 #1 looking to swap the engines in my 2002 k11 facelift, but i dont know which one fits out of the 1.3 and the 1.4? any help is appreciated
Agent_Sm1th Apr 28, 2014 #3 Try and get the 1.4 ecu as well. The 1.0 will run ok but it underfuels under hard acceleration.
OP OP Angus Robinson Apr 28, 2014 #4 thanks alot dont suppose you guys know of any for sale anywhere? also would i need a bigger fuel pump? driveshafts etc?
karlj Apr 28, 2014 #7 Angus Robinson said: thanks alot dont suppose you guys know of any for sale anywhere? also would i need a bigger fuel pump? driveshafts etc? Click to expand... I have one, only 5 days left till it gets scrapped though
Enuo Glorified Electrician Apr 28, 2014 #9 Make sure if you put a CGA3 in you use the CG10 flywheel. Same clutch bit its lighter iirc
Agent_Sm1th Apr 28, 2014 #10 2 kg lighter the 1.0l flywheel. No change regards other stuff, you use the same pump and shafts.
karlj Apr 29, 2014 #11 Dean gummow said: Katlj price? Click to expand... Check the buy and sell section
OP OP Angus Robinson Apr 29, 2014 #12 thanks guys, karlj why would you scrap it? where abouts are you?
karlj Apr 30, 2014 #13 Angus Robinson said: thanks guys, karlj why would you scrap it? where abouts are you? Click to expand... Cause it's taking up space I'm in Gloucester
karlj Apr 30, 2014 #15 Angus Robinson said: how much would you want for it? and how many miles are on it? Click to expand... karlj said: Check the buy and sell section Click to expand...
OP OP Angus Robinson Apr 30, 2014 #16 can you send me a link as i dont know how to get onto the buy and sell bit as im new to this
