tracking and camber
What is the best way to set the tracking. I think my car handle best with a slight toe out but it's not very good on the tyres always seem to scrub the inside wall. This is with zore camber. How do you set your ?
Have mine towing out a little bit as when putting you foot down in a FWD car it pulls them in so if they are towing out a bit they will be straight
Depends what you're setting it up for?
Toe out will give you increased steering response but at a cost to traction and cause as you say scrubbing. But there's no need for excess.
Toe in is the standard for FWD cars but it does the same job on all cars not just FWD
I use 2deg toe out and it's more than sufficient
I had 0.1 degrees toe out and you noticed the slight wander on the motorway but it was so much more planted on turn in it was worth it.
