Camber and tread loss??
Hi all,
Not sure if this is the right area for this... But I've got some minilites 7j 70mm offset with 165/65/R13 so they are stretched and the car is also lowered only 30/40mm and the back tyre's touch the arches soon as a small bump is in the road or even going around around-about, they don't touch much but enough for it to start wearing the side wall tread. Thought a little bit of camber would help but have no idea what needs to do done in order for this to work and also wanted to know from those that have camber how quick the tyres go or how often you get them changed.
Best picture to show the gap, think the suspension is to soft, planning on getting coilovers over the summer but that's along wait, so how easy can camber be done? as the garages wont touch it or tell me how. Any ideas??
Rear camber very tricky, look at maci sans blog, he done it by slicing a wedge out of the axle and welding on some well engineered flange type thing, fronts easy, slot the top hole on suspension
