Tip on changing rear break shoes
CMF_eeden
Hi guys,
any tips on changing the rear break shoes for the drums.
i have not done one before. do you need any special tools? if so which one to get?
any guidance would be great
CMF_33driver
yes yes they are lol
worse if the brake cylinder has burst...
if you can take the nut off, makes its a million times easier, but yeah, it will be tight, and needs to go back on tight!
While your there might be worth doing rear wheel cylinders depending on age and condition (they are pretty cheap to replace). Would also consider getting the drums machined depending on how much of a lip there is.
