supsension?
M
micra_B
awrite folks, i was just wondering what was the best suspension set up for my micra.its a 95 n reg 1.0l if that helps, any help apreciated eg what spring/shock absorbers to use together and how low to go.
cheers
B
Im down 35 on PI Springs and KYB Gas shocks and its a smooth ride and only rubs a wee bit if iv got folk in the back and go over a bump, mind im running on 15s too.
Daz :alien:
erm whiteline full kit..... how come no one said that :S
shocks, springs, adjust panhard rod, camber kit, castor kit, heavy duty front and rear sway/roll bars, front strutbrace.
gonna cost a fair whack but its worth it. also you'll be in for a long delivery wait.time
edit: go down about 35mm best performace drop imo.
and ide go 50mm not 35mm :D lower the better
also,wots your budget cos this stuff not really cheap
lol, suppose it depends on what you want it to look like too.
budget is gonna be helpful considered coilovers?, tho as said 35-50mm springs and kyb's are good
budget of about 300. i think i will use KYB shocks but i dont know what springs.im only going to drop it 40mm at the mo as im running 15s
B
it works out at £169.08 for shocks with delivery and vat but i cant find 40mm drop springs anywhere.
B
Right about not being cheap!!!!
I have . .
Koni shocks
50mm springs
Whiteline Camber Kit
Whiteline Castor/Traction Kit
Whiteline Adjustable Panhard Rod
Whiteline Front Sawybar
Whiteline Read Adj Swaybar HD
All above cost around about £650.00 to £700.00!!
And thats not including fitting and setting up!!!
Unless you can do most yourself.
