Squealing Clutch
RedRocket1
Club Member (Trial)
My clutch is squealing at bite point...like if i hold it there it will just constantly squeel. Anyone any ideas so i can get it sorted as soon as.
Cheers:grinning:
Shero
Dont start with clutches! lol.
but yeh man, like frank says could be the thrust bearing needs greeased up.
OP
OP
RedRocket1
RedRocket1
Club Member (Trial)
Is it easy to do?...I mean i have the engine knowledge of a horse...so will i need some help from the main man Stani?
Shero
yeh, see if you can get a hand from stani, I just took my gearbox out for the first time when i was doing my clutch, its not that hard in the end but if your not sure it helps to have a help. And also get some wd40 or something on all your mounts and bolts / nuts just now so its got time to eat in to it so your not wasting time with goosed bolts. :D
Stani1029
id happily help chris, tell me what you want and its done lol
FRANK- if i were to drill the box to get into oil it do you have a rough point where to drill it? and what kind of oil? 3 in 1?
cheers
frank
cheers
i posted some pics up last year stani, you can get within about 5" of the bearing if you hit the right spot (i,ll have a look, but its the smaller pre98 box tho fwn)
and engine oil/gear oil/chain lube ?
Stani1029
yeah but i thought i remember see-ing a gearbox with about 20 holes in it, all depends on what he wants and if your reading this chris ill be at my lock-up tomorrow just after 12 ;)
OP
OP
RedRocket1
RedRocket1
Club Member (Trial)
Ah you legend!!....Mcdonalds on me;)...Give me a text when your ready then, you needin me to bring anything?
frank
does water n debris get in there and contaminate the clutch frank?
not as yet paul, and i,ve had no sandwich plate thingy between the engine and g/box for years either :wasntme:
(btw i,m struggling to post on your blog fwn the pic loading from page 1 seizes my netbook even tho its now on page 2 :confused:)
pollyp
good thinking paul ;)
incase ya need to quote summing,
click quote,
once the reply window with the quoted message is seen stop the page or hit esc to stop the pics from all loading up,
copy the quoted message string
go back to the latest page
paste the quoted message into the quick reply
then type ur message below
OP
OP
RedRocket1
RedRocket1
Club Member (Trial)
Just an update, Solved the problem using Franks method of drilling a hole (13mm i think) and spraying some lube in and then covering the hole with a grommet. Thanks to frank and of course Stani for doing the job and sortin my headlights;)
frank
glad you,re sorted RR :)
dont worry about the hole tho, as you can see my flywheel is completely exposed on the bottom half (without the tin sheet sandwich plate thingy :wasntme: , and the 2 lower braces lol)
as was my old super s the same, with no problems (removed soon after i bought it in late 1999)
http://www.micra.org.uk/attachment.php?attachmentid=14130&stc=1&d=1264610189
