Spigot Rings
artuan00
Buy & Sell Member
Hi all,
Got an odd set of wheels here and was wondering...
What's the easiest way to measure the OUTER diameter for the spigots? Without a vernier or anything fancy...
Also, Am I right in saying the K11 has uses 59.1mm for the inner?
Thanks all :)
Yeah I tried that, "thought" they were 72mm outer. Then saw things like 69.9 and 72.1 so wanted to get it dead on so theres no play :)
And since the MOT is coming up VERY quickly, (17th) and these are the only wheels with legal tires.. I need to get it sorted :p
im sure your car will pass without spigot rings
This. It won't fail or be advised for not having spigot rings.
As for measuring, the only accurate way you'll get it is with some verniers, or a micrometer. Or you could measure the circumfrence with a tape measure and divide it by Pi (3.14)?
