speedo drive
Just wondering is it possible to change from a electronic speedo pick up on the box to an mechanical drive ?
A few Honda's I've worked on they have been a straight swap, not sure on micras :-/
i'm guessing it prob requires swapping the instru cluster, speedo gear pinion and maybe the loom or swap connector pins if the wiring's different between elec & mech clusters
You missed the question there, he wants to know if the older mechanical speedo drive will fit into a gearbox that has an electronic drive fitted as standard?
