Theres 2 screws up above where your dials are,theres also 1 behind the steering column (you'll have to lower the steering wheel and remove the plastic trim/casing around the column)
Once you've done them the dash around the dials will come off.Theres 3 screws(left,right and top).Once you've removed them theres 3 wiring plugs you'll need to un-plug.Also a connector in the middle that is attached to your milage reader.
