Hi, I am trying to keep my K11 in good nick but need a couple of niggly bits. Can you help? Need n/s rear bulb holder and rear stat for heater as it only works on full blast
I have same problem with heater, only blowing at 3 and 4 position. Do you know will it be problem to pass NCT? because to change it, i have to remove all panel(it is behind glows box) or how to fix it?
take the risistor card out and the little conductor at the top has probably corroided of so, sand it down and go to maplins and get some conductive paint, should only cost around 5 quid and then just paint a good strip from one edge to the other and the problem is sorted
