How much would you say it costs to re-seal the gearbox casing? Just had a health check at nissan and before I tell you how much I was quoted, I'd like to see what you think! :laugh:
if its clear fluid coming from the very lowest part of the box, it may well be clutch fluid, CHECK the fluid level in the brake reservoir ( brake and clutch share the same fluid ) if its low it may be your leak.
Still annoyed I've not been told more by them, for an expensive repair I would have liked to have known the severity of this issue - especially from the dealership!
Had the car jacked up and had a proper look. Not even a proper leak! Could easily be mistaken for a splash mark. Anyway took it for a service and mechanic said was general wear and tear and not to worry too much until later mileage or if it's worse. Also, Nissan wanted £40 to flush and replace antifreeze! Saved £30 DIY (Y)
