Shwipers
#1
Hello all,
So I've had that common issue with the wipers and have replaced the wiper linkages using a replacement set off eBay...should've done the trick, but I've noticed there's still some extra movement from the wipers and they catch the edge of the windscreen when v wet and in windy conditions. There's some play and they move together (a little) when I manually wiggle them up and down with my hands.
Has anybody else still had this lurking issue, and what could a solution be (other than forking out £250 on a new assembly from Nissan)?
#2
This guy says to get the kit off ebay. He also shows how they move around and has couple tips for different options on this. You should take a few moments watch this not sure what method would be best though here.
