Show us your Lows!
Hello people, hoping to lower my k11 soon and want to see what mm looks like what.
If you have a pic, post it, followed by:
Brand/method of lowering
Amount lowered (mm)
Price it cost for your setup
Thanks guys :)
drand
1st Micraversary!
Sorry it's not a great pic.
HOL tarmac rally springs on standard bilstein dampers
-50mm all round
2nd hand just over a ton for springs & dampers
You might find some more pics in the pinned lowering thread.
MicraPRO
Part Of The Furniture
This is 35mm matiz rear lowering springs on standard front micra shocks for a 55mm ish drop on the front... with corsa b rear shocks and chopped springs cut to match the front height.
Cost... not a lot really.
Wheels are 15 inch with 195/45/15 tyres.
Oh and of course a NODSPEED fully adjustable panhard rod.
mas12555
Rare parts nerd #JDM
I just saw show us your lows so I did.. I'm lonely on the k10 side of the MSC no ones really on that side.
god knows how low this is now, scrapes alot and is bouncy! but its on polo coilovers on front, corsa sxi shocks and 4 and half coils cut micra springs on rear, suspension made by the one and only @Enuo , ill try find the photos of the underneath to show you haha
markbognor
Somewhere around 80/90mm. 4ish coils off the front 3ish off the back (I think, it's so long now I'm not sure). All fully captive. Used in this spec for three years or so possibly more, particularly as this is essentially the same suspension as the LX, but with a little more off the springs since then. No changes made specifically for passing MOT's along the way. Rear springs captive by reducing the travel of the rear shocks (new mounting point welded on further down the shaft, and the protruding shaft sleeved up to the thread inside the boot), fronts held captive by wiring the ends of the spring into the cups. Wheels and tyres are 7x13 Et0 with 165/55.
Cost, under a tenner - 1mm cutting disc and a small roll of stainless wire. It's not the comfort option though. I'f I'd been in the position to spend any money, and use time to trawl around some breakers, I'd probably have gone for the next £ per drop method, Matiz struts with dropped perches, and the ubiquitous Corsa and cut rear.
pork
Still havnt painted other side :D
Might go to the jap thing at pod, jus waiting on alternator brackets and pulleys so I can finish off s/c mount.....again.....wanna go on the strip, but might have to stay with the turbo
mas12555
Awesome man, I am not really going out much at the moment. Car is coming first so trying to restrict my spending so I can get more car parts.
