servicing micra
hi
was going to service the micra this weekend, and i was just wondering wat grade of oil to use? the haynes says 15w/40, but then ive been told to use 10w/40 nd 5w/30
would be gratefull for any help you can give
thanks
steve
I recently serviced my car as i had an engine change to a 1.3 and i used Castrol GTX 15w and STP to engine flush as i do with all my engines and then changed filter and poured in 10W magnatec oil with Activ8 mechanical suppliment and also use that in my gearbox..... but if you aint sure then for a definet answer id phone Nissans Dealer and as one of the service manager to tell you!!
J
Hi, i use Mobil 1 5w/30 fully synthetic for the extra protection it gives as i tend to drive quite hard, but Castrol magnatec 10w/40 from asda will be fine, also i'd recommend genuine oil filters.
