M m1cR4 Mar 6, 2011 #1 I have a hole in the rear arch just above the wheel, is this an mot fail? or is it ok cause its not structural? also how would be the best way to fix it? The arch is where the arch shapes thanks.
markbognor Ex. Club Member Club Member Mar 6, 2011 #3 Sharp edges can be an MOT fail. Gaffer tape will "fix" it.
T tat2_mike Mar 6, 2011 #4 markbognor said: Sharp edges can be an MOT fail. Gaffer tape will "fix" it. Click to expand... second that. aslong as its not dangerous to the public you'll be fine mate. (Y)
OP OP M m1cR4 Mar 6, 2011 #5 Tape will do for the mot then :grinning: going to cut a piece out from a scrapper and weld it in i think for permanent fix. thanks.
T tat2_mike Mar 6, 2011 #6 good luck mate, just make sure you cut all the rust out. go further around the affected area, dont wanna be doing it twice. grr
