Hi guys, first post here having just picked up a 51 plate 1.0.
Had a bit of a search to see if anyone else had these symptoms but didn't really find anything so here goes. I find that when driving, in pretty much all gears and all speeds I'm getting a light scraping sound from the front left, a bit like binding brakes. This only happens with the clutch up (ie drive engaged), when the clutch is down the noise is a lot less pronounced.
All gears can be selected smoothly and the clutch is not slipping or vibrating. So, any clues as to the problem? I think I can rule out the release bearing as that only complains when you are pressing the clutch.
Andy
Andy
