I have a faulty O/S headlight on my 98 Micra. The N/S headlight works correctly on main and dip, the O/S side light also works correctly. The bulb and socket are not faulty, but there is no voltage accross the O/S fuse. I presume that it is fed by a relay, but I cannot find it! My 94 has a relay under the bonnet that is missing on the 98. It may be next to the fuses in the dash, but they do not click when I turn the lights on so I cannot ID them. Lots of people have had headlight problems as they are one of the few weak areas on a micra, so I hope there might be some help out there. I need to know which relay switches my light also what is the spac of the one I need to buy so that I can start swapping them to isolate the problem.
Thank you
Thank you
