98 K11 headlight problems again!
I have a 98 1.3gx that has a problem with the N/S headlight(main and dip) not working. Previously the O/S did not work, but the problem was solved by replacing the main switch stalk. This appears now to have been a diversion as the car has done no milage after the problem was apparently solved. The flash works correctly so it is not a bulb fitting problem.
There are quite a few that have had a similar problem on here, but no-one appears to have had and solved a similar problem on a facelift.
My questions are does the 98 still have the cigarette packet relay that the earlier pre-facelift one have and where is it. The Haynes manual is of no use and I am struggling. I need to MOT it soon so any help is most welcome.
Thank you
i dont think there are any relays for the headlights (front what i could see when i fixed mine). My NS was also a bit dodgy but was solved by wiggling the plug (at the headlight) a bit.
