just brought a 1.3 engine for the old 1.0 to a 1.3 conversion and started it boxing day so gear linkage is differnt and drive shafts are differnt the 1.3 is a super a and the 1.0 is just the standerd 1.0l can i any one tell why these are differnt
when i swapped to a 1.3 my g/box had gone, but if it was ok i would have just changed the engine. the only thing to consider is the lower ratio gears will give you better acceleration, but you will use more fuel.
I had the 13 engine and box in mine then swaped the box over for a 1.ltr as where i live theres plenty of hills and banks, and for what you lose on top end it more than makes up for it on the flat and banks, if i were you i would just leave the 1.ltr box in place and as frank says just change the flywheel and clutch over easier and more straight forward. otherwise you will spend a lot more money for very little differance..
