NISSAN MICRA ENGINE CHANGE " NEED ADVICE PLEASE"
Hi there, i have a nissan micro 96 ( block is CG10 ) i have stripped it all down so its just engine block and head, stripped all down , undone bolts on bell housing , split it and i carnt get the engine as as the clearance for the clutch is too much , no room at all to wiggle it free. ADVICE PLEASE, ta jim
there should be plenty of room jim http://www.micra.org.uk/threads/cg10-cg13-diy.60456/#post-682262
Hi il try an answer u right the the engine ur puting in if it's none coil pack 1 it will fit no probs if there both cg10 distribute
What is ment by cg10 is engine number as in cg10=1.0 and cg13=1.3 this number is on the block below the water hose beside the gear box
