nismo front grilles
L
LEEROY_UK
This post is mainly aimed at nismo k12 as hes the only guy with them.
Firstly will they fit the 160 [facelift] secondly where can i get them and how much are they?
Cheers lee
if you want one you'll need to replace the indicators as well(JDM Indicators are a different shape).
The grill will fit a facelifted version
All together you'll be looking at £300 ish
Grill retails in japan for £110
Indicators are £170
the adaptor that goes into the back of the indcator as well is different so you'll need to modify the baton that goes into the indicator. Also the bulbs in japan are a diffrent shape so you'll have to find some small side light bulbs and paint them orange.
To be honest the grill isnt worth the price and the mess on in order to get it to work. Also the indicator bulbs flash faster than standard because you have to use a smaller watt bulb....i need to fit a resitor in the circuit but i havent got round to doing it yet.
i ordered the grill through envy performance. If you tell them i sent you the should give you it at a cheaper price. or you can get it from pro-spec.
###### that way too much ,ill take the rik route a tin of black spray lol
just remove the chrome bit and stick some carbon in there..and tint the indicators
