Needed: Pictures GA16 water pump cut
Hello all,
I need some pictures of the space i have to cut in my chassis dureng a GA16 swap.
Does someone have some?
Please post here! I need it to get my K11 GA16 registered soon!
Kind regards, Jeroen330
GA16DE USDM (115HP), standard engine mounts, CG13DE gearbox, Nismo CG13DE driveshafts..
As i fit the GA16 on the same place as my CG13, i can use the CG13 gearbox and driveshafts.
Why?
Why?
I was thinking of building one pal. So is it more or less a straight swap? Thanks for your help
Personally i wouldnt cut it, but maybe thats just me. From when ive seen them they've been pretty much just a triangular cut.
Have you looked into an electric pump? i understand you have no clearance issues if you fit one. :)
i would portopower the chassis rail over a bit personally :grinning: there,s an inch or two of clearance to the suspension leg (or more with coilies)
