Need Help, new at this!
I have a P reg micra 1lt, with 155/70R13 tyres on it. Someone is willing to give wheels with tyres from their Micra Y reg, which are 165/60R14. Will this work?
Well. It depends on offset, pcd. Width of the wheel isn't really important in this case.
Try willtheyfit.com. Type your current and new spec and see the difference
i put your info into here http://www.carbibles.com/tyre_bible_pg4.html
only 1.17% difference in size as frank said an almost a perfect size replacement if the pcd and wheel offset was the same :)
