My Peco B1 Backbox Help...
D4R73N
I've come across quite a worrie...Now i've just bought a Peco backbox which is Direct Fit, or so they say, I just bought a 'Hag 3' exhaust ring, but it does not fit around the inside of the backbox joint, it would fall inside when fitted, does anyone know if this is normal?
Or maybe had the same problem.
Take it to a garage mate and get them to fit it. Im sure they'l supply the necessary joints or connections to get it on :)
dont be a cheapscate and get it welded on properly! then you have no hassle! At most you will pay £50!
all you have to do is suggest welding! i'll look into it.
