You got it! I guess you have be a certain age.....Loving the Starsky and Hutch theme
Oh BuggerYou got it! I guess you have be a certain age.....
Oh no!...don't mention being of a "certain age" around Ade!You got it! I guess you have be a certain age.....
I should say what the mods are.
We had her on the rolling road yesterday. 102bhp at the fly, peaking at 6800. I'll get a pic of the readout and post it later.
- Scrapyard 1.3 engine (non-coil pack)
- Nismo engine mounts
- Lightened flywheel
- 1.0 gearbox
- Dizzy rev limiter removed
- 1.6 almera injectors
- High pressure adjustable fuel regulator
- Sock air filter
- 4-2-1 exhaust manifold
- Custom built stainless exhaust with Vortex (dyson-ish) box - LOUD
- Standard mapping, with immobiliser removed
- Quick shift gear lever
- Perspex side and rear windows
- Usual MSA safety stuff
What next? Probably a rebuilt base engine and a new clutch. Any other ideas? Preferably not of the mega-bucks variety!
Hi OllyHi Vulture 20
What High pressure adjustable fuel regulator do u have in you rally car? Im looking around and there seems to be loads around?
Thanks olly
Yup, she pulls hard all the way to the limiter.That's a nice looking torque curve ther (although the scale is missing) I take it the car puuls nice and hard to the redline then?
Ta
the speed limiter jools ? and have you disconnected the speed sensor (its very lean at the bottom end eh !)The ECU limiter, the dizzy one has gone. I'll take another pic.
Cheers
Jools
i think there is a speed limiter @ 117mph ? and the rev limiter in the dizzy @ 6900ish.
and we usually disconnect the wire from the speed sensor to stop the ecu closed looping in 3rd, 4th and 5th
and that leanspot low down will just make it a bit flat there eh
Agreed. I need to investigate this. Mind you, the power was dropping off already.If the rev limiter is removed why does the graph end before 7000rpm? It looks like the limiter is still in tbh
Useful read here Vulture
http://www.micra.org.uk/threads/removing-rev-limiter.31924/page-2#post-590912
no matt, and i removed the 1 screw in the back of the speedoDoes disconnecting the gearbox neutral plug do the same as the ECU doesn't then know if it is in gear, or do you need to remove the feed from the speedo to the ECU ?
