tommicraz Jun 12, 2013 #1 hi guy was gona do a bit welding on sill I know I have to disconnect the battery when mig welding but not sure about the ecu?
Noddie Jun 12, 2013 #3 Might as well do the battery. Wouldn't bother with anything else. And don't think iv every disconnect anything.
Enuo Glorified Electrician Jun 13, 2013 #5 Only disconnect ecu etc if you're using TIG with a self-initiating arc, as the high frequency it uses to start the arc can damage some ecu's
Craig Unofficial Member (Gold) Club Member Jun 15, 2013 #6 In the same vein, would you guys drop the fuel tank out when doing sills? Ta
