Micra Engine questions
hey guys
couple of questions about the cg13de engine that if anyone could help me with would be amazing!
1. What does the breather on the top of the gearbox connect to?
2. Where is the oil pressure sensor?
3. What is the red connector below the dizzy for (the one below the water temp sensor spade?)
thanks guys
Only thing I can help you with is the oil switch. That's located underneath the inlet manifold at the back just behind a bracket for the inlet manifold to the engine.
Man in the know would be Franks though.Seriously knows his stuff!!!
