Manifold options
Due to the lack of used Janspeeds knocking about I started looking at other options, I realise that these would take work to make fit, but would they be worth it ?
Vauxhall...
Zetec Focus...
sonic
deffo the zetec, the collector pipe lines up below cyl 3 and the angle of the dangle looks about right :grinning:
The zetec's got the sweep on number 1 cylinder to miss the alternator on my car as well.
This one was a consideration as well,
it's off a Rover 416 K series engine, it's got to be less restrictive than the CG manifold, but it probably wont line up over the ports.
angle of the dangle?... where you looking?
i recon the 4-2-1 off a suzuki swift gti would be the best option, and anyway if you gonaa be modifying it, theyle all fit, cut the flange off, weld a new one on, (micra one) and bend the pipes into possition...
I may have something for you, either a Janspeed or something else, I'll PM you.
Bear in mind that if you use the headers from another car, then you're gonna have to re-work the frontpipe as well.
Craig
