M
Marco
Hi, I am new to this forum but I have been reading it for a week. My girlfiend bought a 1994 (quite old) Micra k11, 998cc, which is in good condition but had the standard radio/cassette and 1 speaker blown off. We both have ipods and therefore decided to replace the speakers and the HU. I have already found very good advice on this forum about how to replace the door speakers, so today I made 2 x 6mm MDF rings, removed the original grills, and fitted 2 JBL GTO 6526 - 16.5cm speakers (however nobody mentioned that I had to drill new holes to fit them with JBL own grills (the standard would not fit the new spacer and the long tweeter)). Anyway, I also replaced the HU with the Alpine 9850ri, used Nissan to ISO connectors that I connected to the Alpine's ISO, but then the HU would not turn on. First thing I've noticed is that the Alpine's ISO do not have the orange wire going into it, but instead the orange wire end in a "bullet connector" (not sure if it is the proper definition). On the other end, The Nissan to ISO connector has the orange wire into the ISO end. The Alpine wiring diagram says that the Orange wire is the Dimmer. The HU sticker says it is the Lighting. I have read on this forum about the earthing problems, but could not be this un-connected orange wire the problem?
Also, if I had to connect the earth to the dashboard, what shall I do without cutting the ISO adaptors? Is the black wire the earth? or which one? ANy urgent help would be very much appreciated so I can use this Sunday (tomorrow) to fix it for good.
Marco
Marco
