hmmm what u need anyway new valves?
u should b able to swap just about anything over as they should b the same apart from the actual head itself as u still need a dizzy 2 run n the cam thing sensor thing on the side would b useless 2 u...just remembered u cant swap cams either... u need a cut on the exhaust cams but it dont have it...well thats off top of my head at 4am
well i rebuilding an engine with an ignition only ECU so i should be able to use this sensor but can i use a auto bottom end with this head if im using the above ECU.
cheers
