k11 autograss car
hi my first post, iam going to be building a class 1 autograss car for my son & myself, the problem i have is i dont know how to rewire the car so it will start, run the fuel pump, & the engine fan, hope someone on here can help with my wiring problems
thanks
michael
Done this a couple of times now, at first i looked around at other micra hotrods and tried to see how they had it done, turns out it was a case of cutting and joining wires until it ran, not a very good way of doing things hahahaha. in the end i got the haynes manual and it turns out its as easy as pie (as long as its pre-nats). 2 live feeds is all that is required, 1 into the red wires going into the little green ecu relay and the other into a thick white/green wire ( i will find the pin number and post it tomorrow) pump was wired via seperate relay to the ignition via kill switch (for racing this is a must). It really is a very simple loom to work with as you only need the engine loom and nothing else
